Shows auto-peered OneConfig information configured on the device.
| auto-peering | Specifies Auto-peering. |
| one-config | Specifies changing the BGP Auto-peering OneConfig configuration. |
| remote | Displays only remote ID information. |
| service | Displays only service information. |
| route | Displays only host-driven static route information. |
| database | Displays only overlay database information. |
| bootprelay | Displays only BOOTP relay information. |
N/A.
To configure remote IDs, use the configure auto-peering one-config remote id [add | delete] id {password [none | {encrypted} tcpPassword]} command.
To configure services, use the configure auto-peering one-config nsi-id id type [nsi | vrf] [add | delete] [[ipaddress {netmask} | ipNetmask ] | ipNetmaskv6] {vr vrname } command.
To configure routes, use the configure auto-peering one-config iproute [add | delete] [host | hostv6] [[ipaddress {netmask} | ipNetmask] gateway | ipNetmaskv6 gatewayv6] {vr vrname } command.
To configure overlay databases, use the configure auto-peering one-config overlay [add | delete] server [address | addressv6] {type bgp-rr } {id id} {password [none | {encrypted} password]} command.
To configure BOOTP relay, use the configure auto-peering one-config bootprelay [add | delete] [ip_address | ipv6_address] vr vrname comamnd.
The following example shows all auto-peered OneConfig information:
# show auto-peering one-config ID : 0 Password : None Route Target : None Anycast MAC : 00:00:00:1b:1b:1b OneConfig Allowed Remote IDs Remote ID Password ----------- ---------------------------------- 23456 None 34567 #$HktHhKOFo/Tk1YtJC1pBz24ZMBHCGg== OneConfig Dynamic Service NSI Service Type VRF Address Installed ------------ -------- ------------ ------------------------------------------- --------- 1000 VRF red 0.0.0.0/0 YES 1001 NSI red 50.1.101.1/24 YES 1002 NSI red 50.1.102.1/24 YES 1003 NSI red 50.1.103.1/24 NO 1004 NSI red 50.1.104.1/24 YES 2000 VRF blue 0.0.0.0/0 YES 2001 NSI blue 50.1.201.1/24 YES 2002 NSI blue 50.1.202.1/24 YES 2003 NSI blue 50.1.203.1/24 NO 2004 NSI blue 50.1.204.1/24 YES 3001 NSI VR-Default 50.1.131.1/24 YES 3002 NSI VR-Default 50.1.132.1/24 YES 3003 NSI VR-Default 50.1.133.1/24 NO 4002 NSI VR-Default 1000:2000:3000:4000:5000:6000:7000:8000/128 NO OneConfig Dynamic Host Static Routes VRF Host Route Gateway Installed ------------ ------------------------ --------------------------- ----------------------- --------- red 50.1.102.101 60.1.1.0/24 50.1.102.101 NO red 50.1.103.104 70.1.1.0/24 50.1.103.104 NO red 50.1.103.104 80.1.1.0/24 50.1.103.104 NO OneConfig Overlay Database Database Address Type ID Password --------------------------------------- -------- --------------- ----------------------- 50.1.133.104 Redis 2000 None 50.1.133.105 BGP_RR 2000 None OneConfig Dynamic Bootprelay VRF Server -------------------- --------------------------------------- VR-Default 50.1.131.105 blue 50.1.201.105 red 50.1.101.105
This command was first available in ExtremeXOS 31.1.
